Help In understanding Rate Of Change in mm per sec
The discussion focuses on calculating the rate of change of a train's left rail elevation over a transition. The train travels at 136.794 kph, and the left rail rises 25 mm over a 60 m transition. To find the rate of change in mm per second, the conversion from kph to m/s is necessary, where 1 kph equals approximately 0.27778 m/s. The formula used is (25 mm * 136.794 kph) / (3.6 * 60 m), with the factor of 3.6 converting the speed from kph to m/s. Understanding these conversions and calculations is crucial for transport engineering applications.
tomtomtom1
Hi everyone
Firstly this is not a homework question, i work in transport engineering. ( i do study part time which is why i sometimes post in the homework section)
Now to the problem.
I am trying to understand how to solve this problem, i already know the answer.
A train is traveling on straight & level track at 136.794kph.
It approaches a transition. The transition is 60m long.
Along the transition the Left Rail rises linearly over the length of the transition relative to the right Rail by 25mm.
Calculate the rate of change the left rail raises over the right in mm per sec over the 60m transition at 136.794kph.
i know that the answer is (25mm * 136.794kph) / (3.6 * 60m)
what i need help with is where does the 3.6 some from? and why do you times 25mm by 136.794kph?
can anyone explain
Thanks
The transition length is 60 m long. In this distance, the rails rise by 25 mm. Doesn't this suggest a slope?
The train is traveling at 136.794 km/hr. How do you convert 136.794 km/hr to a speed measured in m/s?
Yes there is a slope and the slope is 25mm/60m = 1m per 0.416mm which means for every 1m the train travels along the transition the left rail rises by 0.416mm.
1kph = 0.277777778 m/s so 136.794km/hr in m/s is 136.794*0.277777778 = 37.998m/s.
rate of change the left rail raises = 25mm / (time needed to cross 60m)
= 25 mm / (60 m / velocity)
= 25 mm / (60 m / 136.794 km per hour)
Now, 1 km per hour = 1000 m / 3600 sec = 1/3.6 meter per sec
So,
rate of raise = 25 mm / (60 m / ((136.794 / 3.6) meter per sec))
= 25 mm / (3.6 x 60 / 136.794) sec
= (25 mm x 136.794) / (3.6 x 60) sec
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
