Help integrating sin^2(x-pi/6)
  • Thread starter Thread starter K.QMUL
    Integrating
K.QMUL
Hi there everyone,
sin^2(x-pi/6) dx
I have the following integral to solve but am unsure where I should start, I first thought about integrating by parts as I thought you could split it into [Sin(x-pi/6)][Sin(x-pi/6)]. But couldn't seem to figure that out. I was wondering if you could use a trig identity but again am unsure which one.
Any suggestions?
Use the double angle formula. This is a very handy formula to reduce the exponent in a trigfunction appearing in your problem.
Integration by parts works nicely as well, if you are careful with your notation.
which double angle formula would I use, we still have a Sin^2 to deal with
Well, use the double angle formula in which sin^2 appears on its own, of course.
Aha, yes, Thanks for the help
I have completed the question using the double angle formula, could you tell me if you find any errors, as I am still unsure whether I have done this right or not.
Thanks
Thanks
There is a sign error in the end. What is ##\displaystyle \int \cos(x) \, dx##?
Likes 1 person
integrating cos(x) is -sin(x) + c, I took that in consideration as it was 1-cos(x), thus using two negatives = positive, I corrected it to x + 1/2 sin(2x- pi/3).
Does everything look good for this integration? Since I checked on Wolfram Mathematica's on-line integration and the answer they got was
http://integrals.wolfram.com/index.jsp?expr=sin^2(x-pi/6)&random=false
oh, I realize my mistake, integrating cos(x) = sin(x)
You can always check your answer by differentiating it and seeing if you recover the integrand.
So I've completed the question, and checked if I get the original answer by differentiating it. And it seems good. HOWEVER, I have one concern; when you use the double angle formula, can I take 'A' as (x - pi/6) in sin^2(x-pi/6) or would I need to split it somehow. Please clear up my confusion.
What does 'A' represent?
In terms of the question: sin2
Sorry, in terms of the formula: sin2A = 0.5[1-cos2A]
In the identity, you can replace 'A' by anything as long as you replace it with the same thing everywhere. Setting A to ##(x-\pi/6)## is perfectly fine.
