Help involving physics with only an algebreic solution, please.
  • Thread starter Thread starter music2
    Physics
The discussion revolves around a math project for an Advanced Algebra II class, where the Thunder Aeronautical Toy Company (TATC) seeks to determine the height and flight duration of a TIE fighter using the formula h = (V0)(t) - (0.5)(g)(t²), with g set at 9.8 m/s². The user specifically struggles with calculating the initial velocity (V0) required to achieve a maximum height of 100 meters, while successfully solving other related queries. The user emphasizes the need to solve the problem using only algebraic methods, avoiding physics equations. Ultimately, the user reports that they have resolved their issue.
  • Understanding of quadratic equations
  • Familiarity with algebraic manipulation
  • Knowledge of projectile motion concepts
  • Basic understanding of variables and constants in equations
  • Research methods for solving quadratic equations
  • Study the relationship between initial velocity and maximum height in projectile motion
  • Learn how to derive equations from given variables
  • Explore algebraic techniques for isolating variables in equations
Students in Advanced Algebra II, educators teaching algebraic concepts, and anyone interested in applying algebra to solve physics-related problems without using physics equations.
music2
So I have received my semester math project for my Adv. Algebra II class. Here it is:
The Thunder Aeronautical Toy Company (TATC) has hired you as a mathematical consultant for their new project. They are designing a TIE fighter that will launch straight up intot he air and fall back down to the ground very close to the launch pad. They have determined that the following formula can be used to calculate the height (h) of the TIE Fighter at any given time(t):
h = (V0)(t) - (.5)(g)(t2)
.. Where V0 = initial velocity (speed) and g = 9.8 m/s2 (gravity).
TATC has hired you, the mathematical guru, to help them determine certain criteria of their toy. The questions they need answered are:
1.) If TATC designed an engine to give an initial velocity of 30 m/s, what would be the maximum height the TIE Fighter would achiece? 40 m/s? 50 m/s?
2.) What initial velocity would give a maximum height of 100m?
3.) If the initial velocity was 30 m/s, how long would the TIE Fighter be in the air? 40 m/s? 50 m/s?
4.) What if TATC wanted the TIE Fightert o be in the air for 15s, at what initial velocity would their engineers need to design the engine?[/size]
One, two, and four are all extremely easy to figure out. It's two that I'm having trouble on.
I wrote the equation as such:
100m = V0t - .5(9.8)t2
Which I know is right, it's just that I'm not sure what other equation I could form from this problem to potentially set to this one and solve for one of the unknown variables ( V0 and t ).
I cannot use physics equations in this problem. Only algebra II knowledge. I already figured it out with a physics equation, I just can't get it through algebra only.
I don't want the answer, only some advice on where to start, if anyone would be so kind.
Thanks a bunch~
EDIT : SOLVED. WOOO.[/color][/size]
Umm. Might need to move this. I just noticed the sticky. Sorry~
  • · Replies 38 ·
  • · Replies 22 ·
