Kinematics: Solving 2 Projectile Flight Time Diff.
  • Thread starter Thread starter Kyoma
    Kinematics
Kyoma
I have trouble solving this question:
2 projectiles are launched with identical speeds of 30m/s and at angles 40 degrees and 50 degrees with the horizontal, respectively. The difference between the flight times of the 2 projectiles is?
The answer given to me is 0.754s, round up to 3 significent figures.
Just treat it as two separate projectile problems.
Velocity is 30m/s so for the first, resolve the velocity horizontally and vertically at an angle of 40 degrees.
You can then calculate the flight time using just the vertical velocity (v = u + at).
Do the same for the second and subtract the results.
v_{y1}=30sin(40)=19.283, v_{y2}=30sin(50)=22.981
The flying times given that g=9.81m/s^2 are t_{1}=\frac{2v_{y1}}{g}=3.931,t_{2}=\frac{2v_{y2}}{g}=4.685
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
