Help: Lorentz transformations with and without thought experiments
bernhard.rothenstein
Please have a critical look at the lines below:
The simplest derivation of the Lorentz transformation simplified: J.M.Levy "A simple derivation of the Lorentz transformation and of the accompanying velocity and acceleration changes," Am.J.Phys 35,615 (2007) arXiv:physics/0603103 revisited.[1]
Levy [1} presents a derivation of the Lorentz transformation (LT) conisdering that it is the simplest one. It is based on the knowledge of the length contraction formula
L=L(0)sqrt(1-VxV/cxc) (1)
obtained by considering the light clock from its rest frame and from a reference frame relative to which it moves with constant speed V (L(0) represents the proper length of a rod measured measured by an observer relative to whom it is in a state of rest. L representing its distorted length measured by an observer relative to whom it moves with speed V in the direction of the rod.) The derivation is based on the fact that expressing the length of the rod as the sum of the lengths of its components then all the lengths should be measured in the same inertial reference frame.
The single change we make in Levy's approach is to consider that proper length and distorted length are related by
L=f(V)L(0) (2)
where f(V) is an unknown function of the speed of the rod and not of the proper length (to a given rod of proper length L(0) corresponds a single distorted length L.
As in [1] the involved inertial reference frames are K and K' in the standard arrangement. K' moves with speed V in the positive direction of the overlapped OX(O'X') axes. Consider the events M(x,t) detected from K and M'(x',t') detected from K'. The two events take place at the same point in space when the clocks C(x) and C'(x',0) located at that read t and t' respectively. By definition M(x,t) and M'(x',t') represent the same event. All the clocks at rest in K and all the clocks in K' are synchronized following a synchronization procedure proposed by Einstein, respectively.
Consider the relative positions of K and K' as detected from K when the clocks of that frame read t. At that very time the distance between the origins of the frames is Vt, the distance Dx=x-0 being a proper length. The proper length Dx'=x'-0, measured by observers from K is f(V)Dx'=f(V)(x'-0). Adding only lengths measured by observers from K we obtain
Dx=Vt+v(V)dx'. (3)
Considering the relative positions of K and K' as detected from K' when the clocks of that frame read t'. then the distance between the origins O and O' is VDt', Dx'=x-0 is a proper length whereas the length Dx=x-0 measured by observers of K' is f(V)Dx. Adding only lengths measured by observers from K' we obtain
Dx'=f(V)Dx-VDt' (4)
Consider that observers from K and K' measure the speed of a light signal that propagates in the positive direction of the overlapped axes. In accordance with the second postulate they obtain
Dx/Dt=Dx'/Dt'=c (5)
and so we can present (3) as
f(V)cDt'=(c-V)Dt (6)
and (4) as
f(V)cDt=(c+V)Dt'. (7)
Combining (6) and (7) we obtain
f(V)=sqrt(1-VxV/cc) (8)
We have derived so far the Lorentz transformations for the space coordinates of the same event (3)
x'-0=[(x-0)-V(t-0)]/f(V) (9)
and (4)
x-0=[(x'-0)+V(t'-0)]/f(V) (10)
Dividing both sides of (9) and (10) by c and taking into account (5) we obtain the LT for the time coordinates of the same event
t-0=[t'-0)+V(x'-0)/cc]/f(V) (11)
and
t'-0=[(t-0)-V(x-0)/cc]/f(V). (12)
I invite all the participants on the forum to express oppinions about the facts presented above helping to elucidate if the LT could be derived without length contraction or time dilation.
Thanks
"I invite all the participants on the forum to express oppinions about the facts presented above helping to elucidate if the LT could be derived without length contraction or time dilation."
Didn't Prof. Saxl do that in your earlier post?
LT with or without thought experiments
Didn't Prof. Sexl do that in your earlier post?
Thanks. Yes he did. I think I have not very clearly stated my problem.
Many derivations, among them that given by Levy, MacDonalds, are based on the knowledge of the formulas furnished by thought experiments (time dilation,length contraction). My problem is if we can derive the LT simply stating that at variance to Galileo's relativity, in special relativity we could start by simply mentioning that a distortion in lenghth or time interval takes place like dx=f(V)dx(0) where dx is the apparent(?) length, dx(0) the proper length and f(V) an unknown function which depends only on the relative speed V of the involved inertial reference frames and not on dx(0). All that because to a rod stationary in a given inertial reference frame corresponds a single rod in the other one relative to which it moves.
So I think we could start by adding lengths measured by observers of the same inertial reference frame. So we have in I
dx=Vdt+f(V)dx' (1)
and in I'
dx'=f(V)dx-Vdt' (2)
Adding to that
dx/dt=dx'/dt'=c (3)
and combining (1),(2) and (3) we obtain
f(V)=1/\sqrt(1-VV/cc) (4)<br /> and the LT are in our hands.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
