I Help manipulating a Physics equation
  • I
  • Thread starter Thread starter Michael Barilla
    Physics
The discussion centers on manipulating the physics equation mg - m(g/(1+M/2m)) = T to arrive at T = mg/(1+2m/M). Participants suggest making a single fraction and dividing both the numerator and denominator by M/(2m) to simplify the equation. One user successfully combines terms and cancels out variables, ultimately confirming the manipulation leads to the desired result. The importance of proper parentheses placement in the equation is also highlighted for clarity. Overall, the algebraic approach is deemed straightforward and correct.
Michael Barilla
I'm reading my physics textbook and the example has an equation of...
mg-m(g/(1+M/2m)) = T
manipulated so that it equals...
T = mg/(1+2m/M)
I'm not sure how to get this I tried to distribute the m to get...
mg - mg/(1+M/2m)
and multiplying mg by ((1+M/2m)/(1+M/2m)) but could not get the result the book got.
Mathematics news on Phys.org
The approach is good so far. Make a single fraction out of it, then divide both numerator and denominator by M/(2m).
It seems i missed some parentheses; it should be...
mg - m(g/(1+(M/2m))) = T*
T = mg/(1+(2m/M))*
And...
mg - mg/(1+(M/2m))
respectively
Does that change the approach?
I made into one single fraction of...
(mg + (Mmg/2m) - mg)/(1+(M/2m))
canceled out the mg's and multiplied the top by the reciprocal of the bottom...
Mmg/2m x 1/(1+(M/2m)) = Mmg/(2m +2Mm/2m)
Took out M from the denominator...
Mmg/(M(2m/M+1)
Which is equal to...
mg/(1+(2m/M))
Did i do this correctly?
T = mg/(1+2m/M)
mg - mg/(1+M/2m)
Only looked briefly - did not read it;
Mere basic algebra. Nothing tough and nothing unusual.
Looks fine.
Brackets around 2m denominatiors would have been more important than the other brackets by the way.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
11K
