banana_banana
- 11
how to factor this out. 3x^2+3x-2
When factoring an equation, you are essentially breaking down the terms into their simplest form. In this case, "factoring out" means to find the common factor that can be divided from each term in the equation.
The common factor is the number or variable that can be divided from each term in the equation without leaving any remainder. In this case, the common factor for 3x^2+3x-2 would be 3.
Factoring an equation helps simplify it and make it easier to solve. It also allows us to find common patterns and relationships among the terms in the equation.
Yes, you can factor out more than one term in an equation as long as they have a common factor. However, the order in which you factor out the terms may affect the final result.
You can check if your factored out equation is correct by distributing the common factor back into the terms. The resulting equation should be equivalent to the original one.
