How Fast Will the Mass Be Just Before It Hits the Ground?
  • Thread starter Thread starter benp
The discussion revolves around calculating the speed of a 4.0 kg mass just before it hits the ground, connected to an 8.0 kg wheel via a massless string over a frictionless pulley. The problem involves applying the conservation of mechanical energy principle, considering the mass is released from a height of 2.0 m. The user expresses frustration in arriving at the correct answer and requests assistance from others in the forum. Despite the request for help, the user cannot provide their calculations due to their materials being inaccessible. The conversation highlights the challenges of applying theoretical concepts to practical problems in physics.
benp
Here is the problem, I've been trying for a day but can't seem to come up with the right answer.
A 4.0 kg mass is connected by a massless string over a massless and frictionless pulley to the center of an 8.0 kg wheel. Assume that the wheel has a radius of .5 m and a moment of inertia of 2.0 kg*m^2. The mass is released from rest at a height of 2.0 m above the ground. What will its speed be just before it strikes the ground? (Hint: Apply conservation of mechanical energy.)
Well, any help would be appreciated. I've tried cons. of mech. energy, but I come up with a wrong answer.
Hi benp,
Can you please post what you've done so far, so we can find where the mistake is?
Welcome to the forums.
I'd love to but the stuff's in my car (which my sister's using right now). Ugh...if you only knew how long I've been working on this. It's getting late here now (almost 2am) but if you could help any I would apprecaite it very much.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
