mooncrater
- 215
- 18
the problem is as: a very long straight solenoid has a cross section R and n turns per unit length . A direct current I flows through the solenoid . Suppose that x is the distance from the end of the solenoid , measured along its axis:
(a) the magnetic induction B on the axis as a function of x.
(b) the distance x' to the point on the axis at which the value of B differs by η=1% from that in the middle point of the solenoid.
B=μnI[cosβ-cosω]/2
is what I use for the (a) part , by putting the value β and ω where β is angle made by the axis and the end part of the solenoid and ω is the angle made by the axis and starting part of the solenoid.
And n is the number of turns [per unit length.
I am cool with the first part of the question. But the problem occurs with the second part.
I start with the second part as:
magnetic field at the centre of the solenoid = μnI[cos 0 - cos 180]/2=μnI
( What I think that for a long solenoid both the angles tend to 0 and 180 respectively for β and ω
1% deviation from this value is asked thus-
μnI -μnI/100=μnI[cosβ-cosω]/2
99μnI/100=μnI[b/rt.(b^2+x^2)+a/rt.(a^2+x^2)]
now what is x'-----not clear
is x' related to a and b (distance of that point from front and end respectively )----not clear
so that's it .
mooncrater
