How Fast is an Asteroid Traveling Toward Earth?
An asteroid is approaching Earth, prompting a plan to intercept it with a nuclear warhead that needs to impact at 40 km/s. Calculations using the gravitational formula indicate the asteroid's speed varies based on its distance from the Sun, yielding a speed of approximately 12.915 km/s when corrected for units. The discussion highlights the importance of using SI units for accurate results and notes that the asteroid's speed can be optimized by considering its varying velocities at different distances. A recalculation revealed a higher speed of 36.162 km/s at the asteroid's furthest point, alleviating initial concerns about a potential disaster. The conversation emphasizes the need for careful unit conversion and understanding of orbital mechanics in such scenarios.
fleetingmoment
A asteroid is hurtling towards Earth and humankind has decided to fire a nuclear warhead at it in order to avert disaster. In order be most effective the rocket carrying the warhead has to impact the asteroid at 40km/s. The rocket itself travels at 12km/s. What remains is to calculate the speed of the asteroid. During its elliptical orbit, the asteroid's greatest distance from the sun is 2.8 astronomical units (AU) and its smallest 1.00 AU. Its average distance from the sun is then 1.9 AU.
1 x AU = 1.4960 * 1011m[/B]
The formula provided for calculating the speed of the asteroid is:
V2 = G * M * ((2/r) - (1/a))
where G *M = 1.327 * 1020 (gravitational constant times solar mass), r is the asteroid's distance from the sun (the book doesn't specify whether it is the greatest distance or the smallest) and a is its average distance from the sun.
2.8 * 1.4960 * 1011 = 4.1888 * 1011 = r
1.9 * 1.4960 * 1011 = 2.8424 * 1011 = a
Plugging the relevant values into the equation thus:
V2 = 1.327 * 1020 * ((2/4.1888 * 1011) - (1/2.8424 * 1011))
gives 1.668 * 108
Taking the square root of both sides gives:
sqrt(V2) = sqrt(1.668 * 108) ⇔ V = 12915.1
Assuming my answer is correct, I've no idea what the given units are. Whether metres per second, or kilometres per hour, the value still seems incredibly high, given how fast asteroids actually travel. Have I gone wrong somewhere?
Because G and M are SI units. All units must be SI units.
fleetingmoment said:
1 x AU = 1.4960 * 108km
km is not SI unit, you must change into meter
Thanks, Hamal_Arietis
The new value of 12915.1 seems a lot more realistic. Assuming it's also in metres per second. I'm going to divide by 1000 and conclude that the asteroid is traveling at 12.915 km/s.
If you find the asteroid velocity for both its nearest and furthest position from the Sun you will see that there is a range of velocities. I suppose you could find a particular distance where the rocket's speed and asteroid's speed combine to make the optimum collision speed.
Likes Hamal_Arietis
Thanks, gneill,
I plugged in the value for 1 AU and got 36161.5 or 36.162 km/s. I was obviously hasty in concluding that the human race was doomed, based on the value for the farthest distance - especially since the question should have read 'impact the asteroid at at least 40km/s': something I missed when translating the question from the language I'm studying in.
