Why Does a Marble Fall Faster in a Pool Than in a Narrow Tube?
  • Thread starter Thread starter ultraviolent
    Marble Underwater
A marble falls faster in a swimming pool than in a narrow tube due to the difference in water displacement dynamics. In a pool, the marble can displace water freely, allowing for quicker descent. Conversely, in a narrow tube, the confined space restricts water flow and displacement, creating resistance that slows the marble's fall. This phenomenon is similar to the behavior of a ping-pong ball in a tube compared to an open environment, where confinement alters the effects of external forces.
  • Understanding of fluid dynamics
  • Basic principles of buoyancy
  • Knowledge of displacement theory
  • Familiarity with pressure differentials in fluids
  • Research fluid dynamics principles, focusing on water displacement
  • Explore the concept of buoyancy and its effects on falling objects
  • Study pressure differentials in confined spaces versus open environments
  • Investigate real-world applications of these principles in engineering
Students of physics, educators explaining fluid dynamics, and engineers designing systems involving fluid flow and object movement.
ultraviolent
Can anyone give me an explanation of why a marble dropped into a swimming pool will fall faster than if you drop a marble into a water filled tube with a diameter only slightly larger than the marble itself (presume it doesn't touch the walls of the tube). It's something to do with how quickly water can be displaced, but I can't come up with a good explanation.
Thanks,
You're pretty much there. Try thinking of a similar but different scenario. What would be the effect of setting off a firecracker beside a ping-pong ball as opposed to putting them both into a narrow tube and lighting it? Why?
Thanks, I understand now :)
  • · Replies 23 ·
  • · Replies 20 ·
