Understanding the OZI Rule in Particle Physics
aw7879
HELP! OZI rule
Can anyone give me an explanation of the OZI rule in particle physics which is a bit better than "if you can split a feynman diagram in two by cutting gluon lines then it is suppressed"
Looking at http://demonstrations.wolfram.com/TheOZIRuleInMesonDecay/" it seems that if the decay particles contain the original quarks then it is prefered, ie if the original quarks have to annhilate then the decay is suppressed.
There is a nice qualitative justification in Griffiths's Introduction to Elementary Particles (section 2.5), which I quote below in case you don't have access to the text.
The OZI rule is related to asymptotic freedom, in the following sense: In an OZI-suppressed diagram the gluons must be "hard" (high energy), since they carry the energy necessary to make the hadrons into which they fragment. But asymptotic freedom says that gluons couple weakly at high energies (short ranges). By contrast, in OZI-allowed processes the gluons are typically "soft" (low energy), and in this regime the coupling is strong.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
