First Order Differential Equation for Mixture Problem
  • Thread starter Thread starter Outlaw747
    First order
Outlaw747
\frac{dA}{dt}=\frac{5}{3} - \frac{4A}{150+2.5t} lb/min
so basically dA/dt = rate in - rate out
This is basically a mixture problem. There is 10 gals/min going in and 4gals/min going out. Tank starts at 150/300 gallons with 1/4 lb/gal mixture. 5gal/min are coming in at 1/3 lb/gal mixture, other 5 is clean water.
Derived this equation, tried to manipulate it algebraically, but not really sure how to proceed. Can't seem to separate the equation and integrate, all I really know is integration factors and substitution. Any help would be great. Thanks.
Nevermind, got it using integration factor.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
