What Is the Minimum Sample Size n for Pr[Yn≥0.99] to Be At Least 0.95?
CDF of the maximum of a new sample of iid random variables, so that you can use that standard result.In summary, the problem is to determine the smallest value of n such that the probability of Yn being greater than or equal to 0.99 is at least 0.95, where Yn is the maximum value of a random sample from an uniform distribution on the interval [0,1]. This can be solved by considering the CDF of Yn and using the fact that the individual X values are independent and the CDF of Yn can be transformed into the CDF of the maximum of a new sample of iid random variables.
uva123
Suppose that X1,...,Xn form a random sample from a inform distribution on the interval [0,1] and that the random variable Ynmax{X1,...,Xn}.
Determine the smallest value of n such that Pr[Yn≥.99]≥.95
W=Yn-Y1 where W is the range of the sample
Y1=Z
Yn=W+Z
Y1=min{X1,...,Xn}
f(x)= 1 for 0<x<1
F(x)=x for 0<x<1
h(w,z)=0 unless 0<w<1 and 0<z<1-w
G1(y)=Pr(1<y)= 1-Pr(Y1>y)= 1-[1-F(y)]n
=1-[1-x]
Why are you considering the range? Your question concerns the maximum of the sample.
Two hints, using your notation of [itex] Y_n [/itex] as the maximum value.
a) If [itex] Y_n \le y [/itex], you know that [itex] X_i \le y [/itex] for [itex] i = 1, 2, \dots, n[/itex]
b) The individual [itex] X_i [/itex] values are independent
This should allow you to get the CDF of [itex] Y_n [/itex]
What is theoretical statistics?
Theoretical statistics is a branch of mathematics that deals with the study of probability and statistical models. It involves the development of mathematical theories and methods to analyze and interpret data.
How is theoretical statistics different from applied statistics?
Theoretical statistics focuses on developing mathematical models and theories, while applied statistics applies these models and theories to real-world data in order to make predictions and draw conclusions.
What are the main applications of theoretical statistics?
Theoretical statistics has a wide range of applications in fields such as economics, finance, biology, and psychology. It is used to understand and analyze data, make predictions, and test hypotheses.
What skills are required to be successful in theoretical statistics?
To be successful in theoretical statistics, one needs a strong mathematical background, critical thinking skills, and the ability to analyze and interpret data. Proficiency in programming languages such as R, Python, and MATLAB is also beneficial.
What are some common challenges in theoretical statistics?
Some common challenges in theoretical statistics include dealing with complex mathematical concepts, choosing the appropriate model for a given dataset, and interpreting results in a meaningful way. It also requires a lot of patience, persistence, and attention to detail.
