Help understanding a semi-controlled full rectifier
  • Thread starter Thread starter jendrix
    Rectifier
The discussion centers on understanding the output waveform of a semi-controlled full rectifier circuit, particularly why the output voltage (Vout) drops to zero during specific intervals when both controlled rectifiers (T1 and T2) are reverse biased. It is clarified that the inductor opposes changes in current, creating its own flow and affecting the voltage across the resistor. The diodes D1 and D2 function as flyback diodes during this period, allowing current to flow through them. There is also confusion regarding the waveform measurements, particularly the pink signal, which is believed to represent the voltage across T1 and D2, leading to discussions about discrepancies in observed waveforms. The conversation concludes with insights on the behavior of the AC source current in relation to the output current.
jendrix
Hi, I'm analysing the the circuit here
http://imgur.com/a/23GUZ
And I'm having some trouble understand the Vout waveform and why it goes to 0 when when pi<wt<pi+a
If there is always an output current wouldn't there always be a voltage out? The only thing I could think would be the voltage across the inductor cancelling out the voltage across the resistor?
I swear this looks exactly like an old professor of mine hand writing (uddin?)
To answer your question - the Vout waveform goes to zero because both controlled rectifiers (T1 and T2) are not conducting (reverse biased). Are you aware that inductors oppose changes in current by creating their own current flow by using their own stored energy? that is what is happening here.
The path that io is flowing is through the resistor and inductor and through diodes D1 and D2. And you are correct, the inductor is creating the voltage that is dropped across the resistor. think of the path through D1 and D2 as a wire in a conventional circuit and Vo is basically putting your meter across it.
FYI - diodes D1 and D2 are acting like "flyback" or "freewheeling" diodes during this part of the cycle.
It could be :)I'm working through a similar problem and found the notes here
http://www.slideshare.net/maneesh001/phase-controlled-rectifiers
Thanks for clearing up the question, it's clearer now I'm a bit rusty with inductors.
I'm still a bit confused with the voltage across the thyristors, we analysed a similar circuit in the lab and I got a different waveform. I added it to the link, it is the pink line on the oscilliscope? Any idea why there is a discrepancy?
Not sure where the waveforms are
Hi, I added them here
http://imgur.com/a/i67f8
They bottom (pink) signal in each one is supposed supposed to be Voltage of T1, voltage of D2 and voltage of the inductor with a firing angle of 90 degrees - I think they may have been mislabeled
Yellow -Vin
Green -Vout
Blue -Iout
But I'm having trouble what was being measure on the pink signal in each
It would make sense to me if the pink was the voltage across T1 and the voltage across D2, since they conduct during the positive half cycle of Vs, and do not conduct during the negative half cycle of Vs.
Thanks, that sounds right to me
Do you know what the waveform would look like for the ac source current? I thought it would be the same as Iout but 0 from
0-pi
pi+a - 2pi
Or would it be negative during the period pi+a to 2pi?
Thanks
Only time the source current isn't flowing (is 0) is from $$0 - \alpha$$ $$\pi - (\pi+\alpha)$$ $$2\pi - (2\pi + \alpha)$$ $$\vdots$$ Unlike the output current, the source current flows in two directions depending on which rectifiers are on
Thanks for the help, all much clearer now
Not a problem
