Choosing the Right Resistor for a 6V DC Motor Running on a 9V Battery?
  • Thread starter Thread starter wdlanghans
    Electrical Motor
To run a 6V DC motor on a 9V battery for a diorama, a resistor is needed to reduce the voltage. A variable resistor is recommended for adjusting speed, but it's important to note that reducing speed also decreases power. The motor's performance may change when additional weight is added, necessitating further adjustments to the resistance. Directly connecting the motor to the radar dish may present challenges, indicating a need for careful consideration of the setup. Proper resistor selection is crucial for achieving the desired slow rotation speed.
wdlanghans
Hi!
I have a small (about 1") electrical motor that I'm using for a diorama for model train set.
The motor is rated for 6 volts DC and I think it said 150mA but I don't remembered and now I can't find the packaging.
It's this one if that helps
http://http://www.radioshack.com/product/index.jsp?productId=2914699#tabsetBasic"
What I would like to do is run it off a 9 volt dc battery, and I would like for it to move a slow as possible. What kind of resistor do I need?
Thanks!
I would say that a small variable resistor (like the kind at radio shack) would work rather well, seeing as how you can adjust the resistance to suit your needs. Just remember that as you decrease the speed you also decrease the power, and as a result the resistance will need to be adjusted for when you add the weight of the train. In other words, if you get it to spin at the desired speed as is, the resistance will need to be lessened when you put it in the train.
The motor isn't for a train, it's for part of the diorama; to make a radar dish rotate at a slow fixed speed if possible. I was hoping I could do it with a single resistor I just don't know how to figure out which one I need.
But, thanks for the reply :)
So are you thinking direct drive to this rotating dish from the motor? That will be a problem.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
