Help with atomic polarization question
justinbaker
Studying for finals and this is one of the reveiw questions our teacher wanted us to take a look at. A little help please, i got started somewhat as you will see below
"Suppose that we have a lot of noninteracting atoms (a gas) in an external magnetic field. You may take as given the fact that each atom can be in one of two states, whose energies differ by an amount ΔE = 2µB, depending on the strength of the magnetization is taken to be +1 if it's in the lower energy state or -1 if it's in the higher state
a.) Find the average magnetization of hte entire sample as a function of the applied magnetic field B [Remark: Your answer can be expressed in terms of ΔE by using a hyperbolic trigonmetric function; if you know these, then write it this way.]
b.)Discuss how your solution behaves when B--> ∞ and when B--> 0, and why your results make sense."A.) so i am a little confused but this is what i have so far
E1=+µB
E2=-µB
and Probability1=e^(-E1/(KT))
Probability2=e^(-E2/(KT))
also P1 + P2= 1
so is there numbers that i need to plug into find the answer? B.) figure this out when i solve A
So, with these occupation fractions of "North up" and "South up" atoms,
what is the total (net) magnetization?
If T=infinite, you have the same number of Norths as Souths pointing upward,
so the total (and fractional) magnetization is zero.
It is important that the positive Energy is opposite the negative Energy,
or else the sum (and difference) is not a hyperbolic trig function.
ok so i am still really confused here, so is the avg magnetization zero?
E1=+µB
E2=-µB
also P1 + P2= 1
You have two possible values of magnetaziation. Just calculate (first value times the probability of having the first value) plus (second value times the probability of the second value) all that divided by the sum of the two porbabilities. It will give an hyperbolic function.
The probabiilities are
<br /> \frac{1}{1+exp(- \Delta E/k_BT)}<br />
and
<br /> \frac{1}{1+exp(\Delta E/k_BT)}<br />,
but how do I know which probability represents wihch magnetization?
c)
If I am right, the expected value approaches zero both when B -> infinity and when B -> 0, but I can't see why that makes sense...
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
