Help With Circuits Regarding Ohms
  • Thread starter Thread starter aitchfourex
    Circuits Ohms
Using a Y-connector to combine the stereo outputs of a 75-watt amplifier into a mono signal is unsafe and can damage the amplifiers. Each output has a resistance of 8 ohms, and connecting them directly could lead to serious issues, including loud pops or equipment failure. A bridge configuration might be a solution, but it requires specific wiring and a special driver to operate the amplifiers in antiphase. Proper speaker connection is crucial to avoid damaging the equipment. Understanding these electrical principles is essential for safe and effective use of audio equipment.
aitchfourex
Hello, I feel like an idiot because I can't answer this myself (I forgot my high school physics).
I have a stereo amp head that has two speaker outputs at 75w each. Each of these outputs has a resistance of 8 ohms each. My cab, however, is mono, and only has 1 speaker input. The cab I own is an 8 ohm cabinet, but it is mono, and only has 1 speaker input. Would it be safe to use a y-connector to make the stereo outputs mono? I'm not sure of what the final ohms would be.
I drew a crude circuit diagram for you all to visualize.
http://img163.imageshack.us/img163/6374/dfgjg.jpg
I appreciate all the help. Thank you!
*This is NOT a homework question. This is a question with a physics problem I encountered in REAL LIFE*
Most info I have seen wants just the left input when going to mono.
Do NOT do this.
You will simply damage the output sections of one or both amplifiers at best and achieve a loud bang at worst.
You should never common the outputs of amplifiers, especially not 75 watt ones.
It may be possible to configure the outputs to achieve what is known as a bridge configuration, but you will then require a special drives to drive the amps in antiphase. This configuration also connects speaker differentsly as well.
Hope I am not too late.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
