Help with distance between cities?
  • Thread starter Thread starter theintarnets
To find the distance between Panama City and Pittsburgh, the cities' latitudes of 9° N and 40° N are used, assuming they lie on the same north-south line. The formula θ = S/r is relevant, where S is the arc length and r is the radius of the Earth, approximately 6400 km. The latitudes are converted to radians to calculate the arc distance. The distance is determined by solving for S using the difference in latitudes. The discussion concludes with the realization that the calculations can be completed with the provided information.
theintarnets
Find the distance in kilometers between each pair of cities assuming they lie on the same north-south line:
Panama City, Panama, 9° N and Pittsburgh, Pennsylvania 40° N
All we talked about in class is that θ = S/r
I'm really not sure what to do... I assume I'm supposed to be solving for s or r, given that θ1 is 9 and θ2 is 40 but...I'm still not sure what to do.
The distance between them is along an arc - if you assume the Earth is a perfect sphere - we commonly do.
So what am I supposed to do? All I'm given is 9 and 40. I know I need S or R, but I don't know how to get them.
Nevermind, I think I've got it. Apparently the radius of Earth is 6400 km. So I converted the given θ's to radians and then solved for S for the both of them, then subtracted to get the distance between the two :D Thanks for the hint, PeterO
