Help with Efficiency of a motor
  • Thread starter Thread starter mlle-castita
    Efficiency Motor
The discussion focuses on calculating the efficiency of a motor used to raise a load, defined as the ratio of useful output energy to total input energy. Efficiency can be determined by measuring the gravitational potential energy gained by the load and the energy consumed by the motor, using formulas involving power, voltage, and current. The experiment involves raising loads to a consistent height of 25 cm, allowing for comparative analysis across multiple trials. Participants are encouraged to create a spreadsheet to organize their data and calculations, facilitating a clearer understanding of the concepts involved. Overall, the thread emphasizes learning through practice and problem-solving in physics.
mlle-castita
This is from so long ago, I do not even know what the experiment was about any more if anyone can tell me what lesson's name or can explain to me how I can start https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash3/66969_525098604196152_1821545085_n.jpg
The efficiency is defined in terms of total useful output/ total input.
Note that the units of work done and energy supplied are both Joules.
From dimensional analysis you can likely show an equivalence.
So if your motor has done 100J of useful work but has consumed 200J of Energy doing this then efficiency is 50% or 0.5
It looks like your experiment is about using the motor to raise a load over a height. In this case the useful output energy of the motor is the same gravitational potential energy which the load has gained in being raised over a height. You have probably used the same height for all your loads - do you have the value in metres?
To calculate the energy consumed by your motor first consider the power consumed by the motor - which is the product of the current and the voltage. So for each raise by multiplying the voltage by the current you have the power... multiply that power by the time taken to find the energy consumed over that time period... you need to average all your values first.
Once you have this average energy consumed over the same time period and height for each raise (10 raises with 10 different loads) you now have 10 values for the total energy consumed.
what you then do is consider for each of your 10 raises what the total energy gained by the load was... this is done by multiplying the gravitational acceleration constant 9.81 metres per second squared by the mass by the height the mass was raised over. GPE = mgh. You now have 10 values for the useful work done by your motor.
Now all that is left to find how efficiency changes is to divide the useful output by the total input for each value and then multiply by 100.
Voila, you now have calculated the efficiency as a function of changing the mass load.
You can fill in the blank right-most column with this information.
Do you have to write a report too?
Likes 1 person
THANK U SOO MUCH...Yes I HAVE to write a report :S
the height for all of them is 25cm
By the way... I was sent this by someone and I was wondering if you could also help me make sense of it, on the parts you may not have mentioned. I am really bad at these things. :/
''It has been a while since I've worked with this, but I would start at the end of the equation and work my way backwards - based on that sheet, efficiency is (work/energy). From that sheet, we know energy (in Joules) is (W * s). s is seconds and W is Watts.
You don't actually have it labelled, but the work (in Joules) is the weight(force - Newtons)*height(meters). You have the weight there in grams as well as an equation to transform it to Newtons. You don't have heights listed, so I assume the height was the same for each experiment?
Given that, you have to find the equation for Watt, and then just plug in the numbers - find the work based on the force. Find the watts based on the voltage and current. find the energy based on the watts and time, then find the efficiency based on the work and energy.''
Well I could write the whole report for you, but that isn't really going to help you learn anything.
Have a go at it, read my earlier post carefully and start working things out.
A good place to start would be to make an excel spreadsheet -> and then start following the steps.
I will help you with any step/part/physics question you have. But I will not do it all for you - I will help you get there.
Some equations to get you started.
P = VI (power in Watts is the product of Voltage and Current)
W = Fd (Work Done is Force times distance in the direction of the Force)
GPE = mgh (mass times gravitational constant times height)
Why don't you make the spreadsheet, get started with the report and then ask lots of specific questions about specific things?
The steps in my earlier post are really all you need to get started. Unless you didn't understand some of what I said?
I was not good at maths/physics when I started out with it properly. But writing reports and figuring things out really helped me improve :)
thank you, I will get on with it, and I will ask any questions I may have.
:D :D
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
