Help with finding parallel vectors
  • Thread starter Thread starter Aske
    Parallel Vectors
5 replies · 14K views
Aske
The question states "let u= 2i+mj-10k and v=i-3j+nk, find the value of n and m such that u,v are parallel", the second part states asks the same but "u,v are perpendicular"
I attempted to use a dot product solution I guess, because vectors u+v should equal 0 when perpendicular. I'm lost on what to actually do. Thanks in advance.
Remember the definition of the dot product:
[tex]\vec A \cdot \vec B = A_x B_x + A_y B_y + A_z B_z[/tex]
As you correctly stated, for two perpendicular vectors, the dot product is 0.
Let two vectors, [tex]\vec w, \vec q[/tex] be parallel. That means that they're both in the same direction, and therefore, they only differ by some scalar factor R (For instance, [tex]\vec q[/tex] could be 2 times longer than [tex]\vec w[/tex] (R=2) or it could be the same length, but anti-parallel (A negative R value of -1 would achieve that goal) or 2 times longer, but anti-parallel (R=-2)).
So in general, we can write: [tex]\vec q=R\vec w[/tex]
Note that we've written a vector equation. That's actually 3 scalar equations in one. Simply solve for your three variables, [tex]R, m, n[/tex] and you're done.
What's important is that you understand how we've identified parallel\anti-parallel vectors and perpendicular ones. Are these two points clear to you?
If two vectors
u=x1 i +y1 j + z1 k and v=x2 i +y2 j + z2 k
are parallel, then one of them is a multiple of the other
u=a*v (a is a scalar).
That means the same for all components:
x1=a*x2
y2=a*y2
z1=a*z2.
The two vectors are perpendicular if their dot product is 0 which means
x1x2 + y1y2+ z1z2 = 0.
ehild
I somewhat understand what you are saying, so are you saying I need to isolate the unknowns? I still don't fully understand this.
Yes, solve the linear system of equations.
Ok, trying this with the perpendicular qustion it'd be "(2i+mj-10k) . (i-3j+nk)=0". I would have 2 unknowns, how would I solve this. I still don't know how to go about the parallel question.
