Help with Force and Acceleration
  • Thread starter Thread starter BMWPower06
    Acceleration Force
The discussion revolves around solving three physics problems involving force and acceleration using Newton's second law. In the first problem, an accelerometer measures acceleration based on the angle it hangs, and it's clarified that mass is not needed to determine acceleration. The second problem involves a helicopter bucket where participants are advised to identify all forces acting on the bucket and apply Newton's law to resolve horizontal and vertical components. The third problem focuses on calculating the tension in an elevator cable, emphasizing the need to consider both gravitational force and the force required for upward acceleration. Overall, the key takeaway is the consistent application of Newton's second law to analyze forces in each scenario.
BMWPower06
Problem 1:
An accelerometer - a device to measure acceleration - can be as simple as a small pendulum hanging in the cockpit. Suppose you are flying a small plane in a straight horizontal line and your accelerometer hangs α = 14.4° behind the vertical, as shown in the figure below.
http://aycu34.webshots.com/image/16073/2004469205105297433_rs.jpg
What is your acceleration at that time?
in the direction of motion
I figure you use F=MA for this, but there is no mass given... i don't even know where to begin, seeing that the only thing given is the angle.
Problem 2:
A fire helicopter carries a 561 kg bucket of water at the end of a 24.9 m long cable. Flying back from a fire at a constant speed of 43.6 m/s, the cable makes an angle of 48.4° with respect to the vertical. Determine the force of air resistance on the bucket.
This is like the last problem, i was able to find all the sides of the triangle which is made by the weight, but don't know what to do now.
And Problem 3:
A 2016-kg elevator moves with an upward acceleration of 1.86 m/s2. What is the tension in the cable that supports the elevator?
I used F=MA but it said the answer was wrong.
Thanks for the help.
Well for problem three the tension on the cable is the weight plus the force required to accelerate the elevator at 1.86m/s2.
Problem 1
Yes, Newton's 2nd law is what you need here (and in all three problems). Start by identifying the forces acting on the pendulum bob and then apply Newton's law. (You don't need to know the mass.)
so basically i do: (MA)+(2016*9.8)
The forces are velocity and air resistance? I am not really sure where to go from there?
Velocity is not a force; there's no air resistance in this problem.
Hint: Two forces act on the pendulum mass. What are they?
motion and gravity?
BMWPower06 said:
motion and gravity?
"Motion" is not a force. But gravity is. For the other force, consider the tension in the string that pulls on the mass.
Now consider the vertical and horizontal components of these forces. Apply Newton's 2nd law to each direction.
ok so there is the Fg (force of gravity) which points straight down from the mass and Fn (normal force) points straight up. Then i labeled Fn as being 9.8 and having an angle of 75.6 deg. i set it up as being: sin(75.6)x = 9.8 where x= the string from the top to the mass. Is this right? I got 10.12 m/s^2 and it says that it is wrong.
i got it. 2.52 m/s^2! now what do i do for the other 2? I am still stuck.
Problem 2
BMWPower06 said:
Problem 2:
Again, identify all the forces acting on the object--the bucket in this case. Then apply Newton's 2nd law to the horizontal and vertical force components.
Hint: Three forces act on the bucket.
