Help with Fourier transform of T'(x)/x
geetar_king
T(x,t)
What is the Fourier transform of
<br /> \frac{1}{x}\frac{\partial T}{\partial x}<br />
<br /> F(\frac{1}{x}\frac{\partial T}{\partial x}) = \int^{\infty}_{-\infty} \frac{1}{x}\frac{\partial T}{\partial x} e^{i \theta x}dx = ??<br />
Can this be split up using convolution into...
F(\frac{1}{x}\frac{\partial T}{\partial x}) = F(\frac{1}{x})F(\frac{\partial T}{\partial x}) =\int^{\infty}_{-\infty} \frac{1}{x} e^{i \theta x}dx \int^{\infty}_{-\infty} \frac{\partial T}{\partial x} e^{i \theta x}dx<br />
You will need to prove that the convolution of 1/x and dT/dx is (1/x)(dT/dx).
Okay thanks. I was trying to solve
<br /> \frac{\partial^{2}T}{\partial x^{2}} + \frac{1}{x}\frac{\partial T}{\partial x} = \frac{1}{\alpha}\frac{\partial T}{\partial t}<br /> <br />
for <br /> 0 &lt; x &lt; \infty <br /> and initial condition like <br /> T(x,0) = g(x) <br />
with boundary conditions <br /> T(\infty,t) = C_{1} <br /> and <br /> T(0,t) = f(t)<br />
I got stuck with separation of variables and method of characteristics so I was going to try Fourier method
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
