Help with Graphs Homework: Find Velocity at t=7.0s
  • Thread starter Thread starter Mirole
    Graphs
The discussion focuses on calculating the velocity of three particles at t=7.0s using graphs instead of kinematic equations. For Particle A, the velocity is determined to be -10 m/s, indicating leftward movement. Particle B's velocity is confirmed to be -20 m/s after reviewing the graph value at t=7. Particle C's velocity is calculated by finding the area under the acceleration curve from t=2s to t=7s, resulting in a final velocity of 75 m/s. Participants confirm the calculations and clarify the process for determining velocities from graphical data.
Mirole
Three particles move along the x-axis, each starting with v= 10m/s at t_0 = 0s. The graph for A is a position-versus-time graph; the graph for B is a velocity-versus-time graph; the graph for C is an acceleration-versus-time graph.
Find each particle's velocity at t = 7.0s. Work with the geometry of the graphs, not with kinematic equations.
http://img27.imageshack.us/img27/5497/phys.jpg
A=1/2(b)(h)
A=bh
Particle A:
A=1/2(5)(50)
=125m/7s
=-17.85m/s, negative because the particle is moving leftwards.
Particle B:
Since this is a Velocity vs. Time graph, the Velocity axis shows the object to be moving at 20m/s.
Particle C:
At t=2s, the car stops(?) and begins to accelerate till t=8s. At t=7s, would the acceleration be 50m/s^2?
Can anyone check if I'm doing these correctly at all, and if not can you advise me, please?
A:
Not quite. Velocity is the derivative of position - its rate of change. Find the slope of the graph at t=7 and you've got the particle's velocity.
B:
Double check that answer. Very small error, but you've got the right idea. You do just need to find the graph's value at t=7, but take another look at what that value is.
I'm not totally sure how to do C at the moment, I'll keep thinking.
A. Displacement is area under the curve ie, from the line to the x axis. So you would find the areas of the larger odd shape, and the take away the area of the small triangle then divide by t. OR think about what the slope is. it's \Delta y / \Delta x In this case y is displacement, and x is time. So that means that the slope would be what?
B. Yes
C. In an a/t graph, area under the curve would be velocity change.
Ok, so:
A) -10m/s
B) -20m/s
I'm still a bit confused by C, do you just mean the area just under t=2s to t=7s?
A and B are correct, I'm still not sure on C.
Oh, I got it. I found the triangle area from t=2s to t=7s. Then I found the area of the rectangle underneath it. Which ended up being 125-50 = 75m/s.
Thanks for the help!
