Help with Hi Power LED Resistors
The discussion centers on the challenges of selecting appropriate resistors for two high-power LEDs with specific voltage and current ratings. The calculated resistor values of 4.7 Ohm and 8.2 Ohm are questioned due to their wattage ratings, with suggestions to use multiple lower-wattage resistors in parallel and series configurations to achieve the desired resistance while managing power dissipation. There is a recommendation to consider constant LED drivers instead of resistors for better efficiency, especially with a supply voltage of 7.2 V from AA batteries. The possibility of using a single driver for both LEDs in series is explored, emphasizing the importance of ensuring the input voltage exceeds the total LED voltage. Overall, switching to a more efficient driver is advised for optimal performance.
eleones
I have a project with two, separately wired high-power LEDs.
LED #1 is a 1 watt LED rated at 3-4 Vdc at 350/700 mA
LED #2 is a 3 watt LED rated at 2 Vdc at around 350/700 mA
According to Resistor calculations, I get:
LED #R1 = 4.7 Ohm, 2 Watt rating (for 700 mA)
LED #R2 = 8.2 Ohm, 4 Watt rating (for 700 mA)
The problem is I can't find any online vendor that sells common resistors at these specs. Am doing the calculations wrong to arrive to 2 and 4 watt rating or is there a vendor out there that sells these? Alternatively, is there a unique type of resistor that I can substitute for these ratings?
Thanks for any info.
4.7 ohms with 0.7 amps flowing in it will dissipate 2.3 watts, so that seems a bit off, for a start.
What supply voltage are you using?
The 8.2 ohm resistor would dissipate 4 watts, but you would always allow a bit extra.
If you could get half watt 8.2 ohm resistors, you could put 4 at a time in parallel and then put 4 of these banks in series.
So four 8.2 ohms in parallel = 2.05 ohms
Then 4 of these in series gives 8.2 ohms but at 8 watts.
I know it is only a few watts, but these circuits are very inefficient. At this level, you probably should be looking at swtch mode buck supplies. The following is an example, but may not be the best around:
http://www.simplecircuitdiagram.com/2010/02/11/wide-input-voltage-range-high-power-led-driver/
This would give you immunity from supply variations as well as reduced current consumption from the supply. Maybe you could go to Maxim's website and get the data sheet for the MAX774 device.
Thanks for the reply. I'm planning to drive with 6 AA batteries (7.2 V). It's been recommended that I use a constant LED driver instead of resistors. I found several 3W drivers rated for 3W LEDs powered by 3-12 Vdc, but I can't find 1W LED drivers that can be powered by anything below 12 V. Unless it's possible to get away with using one 3W driver to power both LEDs in series?
Here are links to two of them I found:
http://bit.ly/90UmKV
and
http://ledsupply.com/03023-d-n-700.php
Thanks
I looked at the data sheet for the second one. It shows LEDs in series. (see P5)
The only limit is that the input voltage must be higher than the total voltage of the LEDs. This should not be a problem.
They talk about 95% efficiency, so if you got anywhere near that you would be much better off.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
