Help with interpretation of question. (Differential equations)
sid9221
http://dl.dropbox.com/u/33103477/Linear%20oscilator.png
I am having trouble understand the question, what I have done its solve the equation using the substitution x=e^{rx}
Then, I have the solution given by:
x(t)=c_1 e^{t(\sqrt{\gamma^2 - \omega^2 })} + c_2e^{-t(\sqrt{\gamma^2 - \omega^2)}}
So at x(0)=0,
c_1 + c_2 = 0
and, x'(0)=v
v=c_2(\sqrt{\gamma^2 - \omega^2} - \omega) + c_1(\sqrt{\gamma^2 - \omega^2}+\omega)
Not quite sure how to proceed as if \omega is greater than \gamma I get imaginary values and the opposite gives real, but what does that mean ?
Assuming everything is correct and I see it is correct up to taking the derivative and plugging in zero (I was too lazy to take the derivative). If omega > gamma, you would have e^{ait} where I am using a = radical.
What is e^{ait}\mbox{?} Can you rewrite e in this form as some other transcendental?
If they are real, you just have a DE with of the form Ae+Be.
Equal you just have a constant.
Also, I see you didn't solve for you constant. You set it up but that was it.
\begin{bmatrix}1&1&0\\
\sqrt{\gamma^2-\omega^2}-\omega & \sqrt{\gamma^2-\omega^2}+\omega & v
\end{bmatrix}
When you solve this system, what do you get for c_1,c_2?
Okay so working out c_1 = -v/2\omega and c_2 = v/2\omega what does that mean for the formula I don't get what I'm suppose to interpret from these results ?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
