• Support PF! Buy your school textbooks, materials and every day products Here!
Help with my homework please
  • Thread starter ph0bolus
1. Homework Statement
I'm supposed to just differentiate these 2
1)http://img132.imageshack.us/img132/8439/img0543hd2.jpg [Broken]
2)http://img142.imageshack.us/img142/8544/img0544sr0.jpg [Broken]
And use implicit differentiation to fidn dy/dx on these 2
3)http://img511.imageshack.us/img511/3284/img0545gy6.jpg [Broken]
4)http://img231.imageshack.us/img231/6163/img0546ew3.jpg [Broken]
I took a crack at both of them the 1st two i couldn't really complete, and the last two I'm not really confident on them. Any help would be greatly appreciated.
Answers and Replies
334
Since you didn't do either of the first 2 correctly:
For 1) You didn't apply the chain rule right
For 2) You didn't apply the multiplication rule at all
For 3) What's [itex]\frac{d}{dx}(6)[/itex]?
For 4) You did fine until you didn't divide through totally properly on the second to last step.
You need to slow down when doing these problems.
[tex]\frac{d}{dx}(\sin x)=x'\cos x[/tex]
31
would the third one be
y'=-y^2-2xy/(x^2*2y)
for the last one would it be
y'= 1-2y/2xy?
1,750
You factored a common term of y' incorrectly. Review your Algebra, it's not too late!!!
thanks..that helps a lot..
ok reviewed it
3) y'=-y^2-2xy/x^2*2yx
4) y'=1-2y/2x2y
Let's do a review ... factor and solve for y:
[tex]y+3x+zy=xy[/tex]
31
sorry math and physics is not my forte
i guess the review problem would be
y=3x/xz?
[tex]a(x+y+z)=ax+ay+az[/tex]
Your mistake is that, you're not factoring out the common term ...
[tex]y-xy+zy=-3x[/tex]
Common term y
[tex]y(1-x+z)=-3x[/tex]
[tex]y=-\frac{3x}{1-x+z}[/tex]
Math wasn't my fav. subject either, but it's definitely useful so deal with it.
1,750
Notice on your 2nd to last line for your last problem ... you divided only the 1st 2 terms ... it has to be EVERYTHING!
31
damn..can't believe it was that simple i forgot about it maybe the "factor" was a dead giveaway.
So if i applied that to problems 3 & 4
3) y'=-y^2-2xy/x^2+2yx
4) y'=1-2y/2x+2y-1
please tell me i did it right..
1,750
Yes, those are good now.
OrbitalPower
Did you rework the first one?
When I do the chain rule of trigonometric functions, like in problem one, I always think of the regular function, sin x, with the stuff stuffed in, and then the derivative of the stuff.
As rocomath said d/dx[sin u] = (cos u) u'
G(x) = sin 3x and G'(x) = 3 cos 3x
u = 3x cos u = cos 3x
u' = d/dx [3x] = 3
Also, with trigonometry, it helps to pay attention to the parentheses.
Studying these may help quite a bit:
y = cos 3x^2 = cos (3x^2)
y' = (-sin 3x^2) (6x) = -6x sin 3x^2
y = (cos 3)x^2
y' = (cos 3) (2x) = 2x cos 3
y = cos (3x)^2 = cos(9x^2)
y' = (-sin 9x^2)(18x) = -18x sin 9x^2
y = cos^2 x = (cos x)^2
y' = 2(cos x) (-sin x) = -2 cos x sin x
31
yeah, i know how to do chain rule..
derive outside, leave inside, then derive outside, but since theres it's 3pi(x)/2 would i use the quotient rule or what. I know 3 pi/2 is a constant.
458
What is the derivative of kx if k is a constant? It's just k, no quotient rule needed for that. The chain rule is the derivative of the outside function times the derivative of the inside function.
OrbitalPower
Well, the chain rule is where the mistake is being made. You don't have to worry about the quotient rule.
Take a look at:
cos (3x^2)
IN problem one you posted, you have as the first "term" sin ((3 * pi * x) / 2) as the minuend.
So it's cos ((3 * pi * x)/2)
times the derivative of 3 * pi * x / 2.
You pull out the constant, which leaves you with the constant times the derivative of x, which is one.
So the first term is ((cos (3 * pi * x)/2) * 3 * pi)/2
You can do the other one the same way.
It helps to study example of the Chain Rule to master it. The Chain Rule is so important that you will seldom again differentiate any function without using it.
31
yeah i wrote it down wrong..
31
yeah i've had this it's whats next is what i have the problem on..
cos(3*pi*x/2)(3*pi/2)-sin(3*pi*x/2)(3*pi/2)
do i just leave it like that? or should i rearrange the constant to the front.
Doesn't matter ... it's still the same. However, it's customary to write the constant in the front. Also, in this case, they both have a common term of that same constant, so factoring it out would be the best choice.
[tex]y'=x'(\cos x-\sin x)[/tex]
31
Ok got it...
On the second one I used the chain rule and ended up with:
-2(2x-5)^-2 * (12x-30)(x^2-5x)^5
and now i'm stuck yet again.
Related Threads for: Help with my homework please
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
