How Do You Calculate the Total Force on the Hoover Dam?
  • Thread starter Thread starter pete22
    Physics
To calculate the total force on the Hoover Dam, consider both the hydrostatic pressure exerted by the water and the gravitational force of the dam itself. Use Pascal's principle with the equation P = P0 + ρgh, where ρ is the water density and P0 is atmospheric pressure, to determine the pressure at the base of the dam. From the pressure, apply P = F/A to find the force exerted by the water, taking into account the area in contact with the dam. Additionally, calculate the weight of the dam using w = mg, where m is the mass of the dam. Summing these forces will yield the total force acting on the dam.
pete22
i have a problem where i have to find out how mych force the hoover dam has on it. i have to take into account the force the water is putting on the dam and the gravitational force that is being created by the actual wall taking into account the mass of the wall. help i don't know where to start.
have you done fluid mechanics yet?
Regards,
Nenad
Use Pascall's principle and the fact that p =p_0 + g*h*j where p_0 is the atmospheric pressure and j is the mass-density of water.
regards
marlon
Like marlon said, use the equation:
P=P_0 + \rho gh
where: \rho = density of water = 1.00x10^3 kg/m^3
and P_0 = 1.01x10^15 Pa
When you find P, then you use the equation for P (pressure): P = F/A to solve for F
(A = the area of water in contact with the dam.)
Once you have this, you have the Force that the water exerts on the dam (make sure you find both Force vectors. One side will have a large vector, where the other side, while still having a vector, will be very small)
Your next step will be finding the weight of the dam itself. Use the formula
w=mg where w is weight.
Add these up and "Eureka! You've found it!"
(Pardon the pun) :smile:
Paden Roder
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
