Help with proving identities please
  • Thread starter Thread starter nevag07
    identities
The discussion revolves around proving specific trigonometric identities, including expressions involving sine, cosine, and tangent. Participants analyze various methods for proving these identities, emphasizing the importance of foundational definitions rather than assuming established identities like sin²x + cos²x = 1. One contributor suggests translating problems into triangle form to simplify understanding and solutions. Another counters that while assumptions can be valid, they may limit the applicability of certain methods. The overall focus is on finding effective strategies for proving trigonometric identities without relying on assumptions.
nevag07
i need help with proving these identities
1/sinxcosx - cosx/sinx= tanx
1/1+cosx=csc^2x-cscxcotx
sinx/1-cosx + 1_cosx/sinx = 2cscx
i would really appreciate this
1. \frac{1}{\sin x \cos x} - \frac{\cos x}{\sin x} = \frac{\sin x - \sin x \cos^{2} x}{\sin^{2} x \cos x} = \frac{\sin x(1-\cos^{2}x)}{\sin x(\sin x \cos x)} = \frac{\sin x}{\cos x} = \tan x2. \frac{1}{1+\cos x} = \frac{1}{\sin^{2} x} - \frac{\cos x}{\sin^{2} x} = \frac{\sin^{2} x(1-\cos x)}{\sin^{2}x(\sin^{2}x)} = \frac{1}{1+\cos x}you do the last one.
you should come up with \frac{2-2\cos x}{\sin x(1-\cos x)} Now factor this, simplify, and see what you get.
Proof
Remember your triangles.
sine is y/hypotenuse
cosine is x/hypotenuse
tangent is y/x
and X^2 + y^2 = hypotenuse^2
Translate your problems into triangle form and the answers will pop out.
The problem with Courtrigrad's approach (while it is valid), is that he assumes the validity of the identity sin^2 X + cos^2 x = 1. When proving trig identities, it is usually more educational to go back to the basic definitions and not assume anything.
There is nothing wrong with Courtrigrad's method, I don't understand your claim that he assumes anything, I would take
sin2x + cos2x = 1 as a given because it is always true, and does follow from the basic definitions of the trigonometric functions. This is not the case with your method, however, your method to be technical will only work for angles strictly between 0 and 90 degrees and I wouldn't really call your definitions the basic ones.
As long as you don't carry things over and multiplying both sides like you would in algebra (you can find common denominators), that method is fine. The thing to remember is that you need to solve one side until you get to the other.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
