How to Tackle Challenging Questions in the Senior Maths Challenge?
  • Thread starter Thread starter david18
    Puzzle
The discussion focuses on strategies for tackling challenging questions in the Senior Maths Challenge, particularly a specific question from past papers. Participants emphasize the importance of using logical deduction and elimination methods to determine the placement of numbers in a grid-like format. They suggest starting by analyzing known sums to identify constraints on the possible values. The conversation highlights that while experimentation can be time-consuming, a structured approach can lead to a solution. Overall, the key takeaway is the value of deductive reasoning in solving complex mathematical problems.
david18
Hi I am taking senior maths challenge this year and was looking over some of the past paper questions. I did the first 10 questions and they seemed okay (although i took a bit of time on the year question which turned out to be monday) and looked at q10.
http://www.wpr3.co.uk/UKMT/smc.html (scroll to q10)
Is there any method to tackle this kind of question? I could spend a lot of time experimenting with different numbers but I'm usually used to having some kind of method to go through the question. Any help on a good logical approach/method would be appreciated.
Thanks.
Mathematics news on Phys.org
Well, you can start by noting that the leftmost column sums to 13 so the two empties sum to four. This forces one tow be 3 and the other to be 1, since duplication isn't allowed.
CRGreathouse has the right method. Use the same logic on the bottom row (ie figure out which numbers HAVE to be used, and why). Then you should be left with three numbers that have not been used. From there, you need to think, what happens if the top column is 9 1 3 (descending), then whcih of my three numbers left would work (if any.. hint hint).
So the trick is, to assume that there is only one possible place for each of the nine numbers. If that is the case, you can work out deductively what has to go where.
I don't know if there is a shorter method than to use the process of elimination. I am not sure if it is possible that it might have more than one solution.
Anyways, it seems the sequence
* * 7
* * 2 6 5
works.
yeah thanks alot, i worked the answer using the same idea as crg and diffy said and got the same answer as nesna.
Im not used to these kinds of questions as the national exam questions always have a strict method to follow.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
15K
13K
