Help with the derivative of the Dirac delta
Delerion24
Try developed this expression
The equations are in the images
My goal is to develop the equation 21. You should asume that \delta(r_2-r_1)^2 =0. These is named renormalization. Then my question is , do my computes are correct with previous condition ?
@Delerion24 -- Please make it a habit to post your work at PF using LaTeX, not via images. You can click on the "LaTeX Guide" link below the Edit window for our LaTeX tutorial. What software did you use to write the equations in your image? Perhaps it is easy to port your work to LaTeX and add that as a reply? Thanks.
Likes Wrichik Basu, topsquark and robphy
I guess this is a Distributional derivative, or there's something else I'm not aware of here? I mean, are we referring to the Dirac delta Distribution. i.e., Generalized function?
Delerion24 said:
Homework Statement: Try developed this expression
Relevant Equations: The equations are in the images
View attachment 314422View attachment 314423
No, the square of a delta distribution is undefined.
Where did your eq(21) come from? You say that it "is" (8b). But then later you say that eq(26) is 8b. Then you say "9 isn't 2", which I guess refers to other equations you haven't shown.
It's very hard to help when you all you show us is a mis-sequenced, incomplete, mess. :headbang:
I just started reading about holomorphic functions, maybe switch to complex coordinates and integrate around a contour. If you expand your Schrödinger equation correctly, then you should just see the wave function with a time evolution operator, like a decaying exponential tacked on the side. Let me think about this one.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
