Help with total work done by friction problem
The discussion focuses on deriving the expression for the total work done by friction on a block sliding down a plank. The initial potential energy of the block is expressed as PE = mgh, and the participants explore the relationship between friction force and normal force, emphasizing that the friction force equals the normal force multiplied by the coefficient of friction (uk). There is confusion regarding the incorporation of height and the calculation of the normal force, with suggestions to draw a diagram to clarify the forces acting on the block. The importance of resolving the block's weight into components is highlighted to determine the normal force accurately. Overall, the thread emphasizes the need for a clear understanding of forces and energy transformations in the problem.
debrickshaw
A Block of mass (m) slides down a plank of length (s) from a height (h) down to the ground. The friction between the plank and the block is uk. Derive and expression for the total work done by the force of friction done by force of friction on the block
W=Fd
F=W/d
d=W/F
Wtotal=1/2 mv^2
at top PE = M=mgh
honestly I've been staring at this damn problem for a half an hour and that's all I've got, any help would be very appreciated
Work equals force times distance. Can you figure out what the magnitude of the friction force on the block is?
ok, so mg(mk) is the magnitude of the friction force
so w = mg(mk) * s?
i mean mg (uk)
Careful. The friction force is equal to the normal force times uk. Is the normal force on the block equal to its weight in this situation?
ok, so F of friction is equal to sin (theta) x uk x mg?
ok so this is what I've worked out so far
W= F x D
D= -SF=uk x m x g
but i don't think that's right, i can't figure out how to incorporate the height, nor do i know how to get the normal force
Draw a diagram. Resolve the block's weight into two components, one in the direction parallel to the ramp, and one in the direction perpendicular to the ramp. The normal force is equal in magnitude and opposite in direction to this perpendicular component of the block's weight (we know this because there is no acceleration in the direction perpendicular to the ramp).
Once you have your diagram, you will be able to see that the angle between the total weight vector and its perpendicular component is the same as the angle of inclination of the ramp.
Hint: In your second last post, sin(theta) is not correct.
