I Time Dilation: Get Answers to Your Questions
Junkwargo
Hi, I've always had a doubt concerning time dilation, and today the curiosity got the best and I decided to ask people that know their stuff, you people. Maybe the question has been asked before, but I did a quick search and couldn't find it, sorry if that's the case. Well, here it goes.
As I understand, time dilation occurs by different velocities or positions relative to a gravitational field. In the case with velocity, I understand that if an observer has a clock, let's call it clock A, and there is also a second clock (clock B) moving relative to the observer, then clock B will register a slower passage of time than clock A. Now my question is this, if velocity is relative, why does clock B ticks slower, if from the point of view of clock B, it is clock A that's moving, and should therefore be the slower clock? Are both clocks slower? How does that work?
I'm not a physicist (biologist here!), so my understanding of these things is shallow at best. Any help would be greatly appreciated.
Neither clock is actually slower. They both tick at the same rate of one second per second and they are both perceived by their moving counterpart as ticking more slowly that it. That is, if you can I are moving relative to each other then I see your clock ticking slower than mine and you see my clock ticking slower than yours whereas in each of our local frames, our clocks are both ticking at one second per second.
This HAS been discussed here, at last count, 8,746 times.
Likes m4r35n357
When I use the forum Search feature (at the right of the toolbar at the top of the page) to search for "time dilation" in this forum only, I get 4 pages of hits. I think you need to try again.
Time dilation due to different velocities occurs whether there is a gravitational field or not. Since that's the case you're asking about, I would leave out the gravitational field and just concentrate on the simple case of nonzero relative velocity. The answer @phinds gave addresses this case.
Imagine you are driving along a straight road at 30mph. Imagine another straight road crosses yours at angle ##\theta##. Look out of your side window at a car also doing 30 on the other road. It'll fall behind because its speed in your forward direction is only ##30\cos\theta##. But the driver of the other car can look out of her window at you, and will see you falling behind for the exact same reason.
Who is really falling behind? The question doesn’t make sense. The effect is entirely a result of disagreeing on what "moving forward with no sideways component" really means.
This is closely analogous to time dilation. Remember that time is a dimension in spacetime. Remember also that both clocks A and B can regard themselves as stationary - that is, moving in time but not space. Noticing that the other clock ticks slowly is like noticing that the mile-markers on the other road don't match up to the ones on your road. The mile-markers are the same distance apart but with different definitions of "going straight forward". In relativity the ticks of the clocks are the same time apart, but with different notions of "moving only in time".
Likes SiennaTheGr8, Nugatory and laymanB
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
