HELPConservation of momentum lab
  • Thread starter Thread starter pie877
    Lab Momentum
The discussion revolves around a lab experiment involving a film canister propelled by a reaction between baking soda, citric acid, and water. Participants are tasked with determining the optimal amounts of each ingredient to achieve maximum height, which is recorded at 6 meters. Key equations discussed include basic kinematics and conservation of momentum, although it is clarified that momentum equations are not necessary for this scenario. Instead, participants are advised to use energy conservation principles or specific kinematic equations to solve for velocity. The conversation concludes with confirmation that the total mass used in calculations should include the canister and its contents.
pie877
1. we did a lab putting baking soda, citric acid, and water into a film canister and we had to find the amount of each ingrediant to give the max height when propelled by material, and once we have that we time it and the questions is to find the velocityof the canister when the propellant erupts
m (of canister) 4.1g
m (of baking soda, citric acid and water) 7g
m (of water) 10 ml (10 g)
time (from liftoff to landing) 1.29 s
max height 6m
we know the basic kinematics equations such as:
d=v1t+1/2at^2
v2^2=v1^2 + 2ad
also we know conservation of momentum equation
p1=p2
m1v1+m2v1+m3v3=m1v'1+m2v'2+m3v'3
3. The Attempt at a Solution
i tried using the 1st equation d=v1t+1/2at^2 but my speed was 12.6
when t=.645s (time to reach max height) and a=9.8m/s^2 and d=6 m (max height)
but I am not sure if we need to use the momentum equation? and how t go about to this lab?
welcome to pf!
hi pie877! welcome to pf! :smile:
(try using the X2 and X2 icons just above the Reply box :wink:)
no, energy will do …
either use KE + PE = constant,
or use one the standard constant acceleration equations (not d = v1t + 1/2at2, it has too many unknowns, use one with v2 in … I'm assuming the canister is going straight up :wink:)
Hi pie877, welcome to PF :)
(Please refrain from using bold face - it hurts my eyes!)
max height 6m
Can you explain how you found a speed of 12.6 when t=.645s?
Btw, the momentum equation is not of use in this case.
Alright I'll try that and yes it's going straight up
Thx
should i get the same answer tho?
cuz I am not sure which mass to use for KE+PE=constant
like mass of canister or mass of canister and contents lol
hi pie877! :smile:
(just got up :zzz: …)
use the mass of whatever goes up …
any contents that get left behind don't count :wink:
Thanks I got it to work lol :)
