HelpHow functions are driven from graphs?
  • Thread starter Thread starter gholamghar
    Functions Graphs
gholamghar
Hello
my question is how and with which methods Equations are derived from graphs,for example the graph below is for specific energy in open channel flows,and the equation to it is :
E=y+(q^2)/2*g*y^2
how this equation has been obtained from the graph?
if in Excel you add a trendline to this figure and then you find the equation with Excel,the best it gives you is this:y = -0.0453*E^2 + 1.6595*E - 2.3539
and this is totally different with the above equation,
so how do they obtain equations from the graphs?
thanks
Mathematics news on Phys.org
First, the word is "derived", not "driven" or "drove"- that's a whole different thing!
Second, the graph you show can't possibly be of the form "E=y+(q^2)/2*g*y^2". That gives a parabola with horizontal axis and this doesn't have a horizontal axis. Also if those two lines are asymptotes, the graph is not a parabola, although it can be a hyperbola. Assuming that the graph is a hyperbola with asymptotes y= x and y= 0, and center at (0,0), then we can rotate the graph clockwise by \pi/8 radians so that the axes are the E-axis and the y-axis. Now the asymptotes are y= tan(\pi/8)E) and y= -tan(\pi/8)E)[/itex] and the equation is
tan^2(\pi/8)E^2- y^2= A
for some positive number A. You can determine A by the requirement that Emin, yc satisfy that equation.
thank you for reply,i think you have read the equation i wrote in a wrong way,now i rewrite it:
E=(y)+(q^2)/(2*g*(y^2))
g=9.8 m/s^2
q=constant
y=height
E=energy
so it is not a parabola.
but is there any reference book that has different graphs and their equations?
i have a post here:
https://www.physicsforums.com/showthread.php?t=325862
i need to find the equation for the graph in that post,the graph is like two continuous Cosine digrams but with different amplitudes,is there any reference for these kind of problems?
thanks again
You are right- I did not see that the "y^2" is in the denominator.
gholamghar said:
Hello
Since this graph isn't pretty conventional and nothing too absurd, you need to look at its features and simply use logic to solve them.
Since the graph has asymptotes of y=x and y=0, this means that as y \rightarrow \infty then x \rightarrow y,0
Such an equation that will accomplish this task is:
x=y+\frac{1}{y}
notice how in the RHS, the fraction is what changes the entire structure of the graph. As y \rightarrow \infty then \frac{1}{y} \rightarrow 0 so the graph tends towards y=x but as y\rightarrow 0 then \frac{1}{y} \rightarrow \infty so now the graph tends towards y=0
but we need a general equation for this, and basically that would be:
ax=ay+\frac{b}{y^k} for some constants a,b,k
for your graph, it is already given that a=1, b=\frac{q^2}{2g} and k=2
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
