Here is a Theoretical Question I have been pondering
  • Thread starter Thread starter mightyhealthy
    Theoretical
Mixing cream into hot coffee immediately is recommended to achieve a better blend and avoid clumping, especially with dry creamers. Adding the cold cream lowers the coffee's temperature, allowing it to cool down to a drinkable level faster without burning the mouth. The cooling rate of the coffee is influenced by its temperature and the volume of liquid, with a larger volume cooling more slowly. While mixing cream before leaving Dunkin Donuts may retain heat longer, the immediate blending aids in achieving a desirable drinking temperature. Overall, the choice depends on personal preference for temperature and blending efficiency.
mightyhealthy
Here it goes:
You purchase a cup of coffee at Dunkin Donuts. The coffee is about 90deg. in a styrofoam insulated cup. The main question is: Should you mix your cream, which is about 5deg cels, in the coffee at dunkin donuts or wait til you get home? The temperature outside is about 25deg. Home is about 5-10min away by car. It's not a trick question. Ok it should be that you mix the cream before, but why?
Assuming the intention is to keep the coffee as hot as possible - milk later.
The cold milk will rise in temperature on the way home.
The rate of cooling of the coffee is proportional to temperature so cooler (milky) coffee would cool more slowly but at any point in the cooling curve it will be cooler if the milk is added.
Also, the rate of heat loss by the coffee is slower not only due to the insulated cup, but the greater volume of the fluid, which makes a greater ratio of mass/surface area. The temperature change in the creamer will be more rapid because it is a smaller body.
But for me, the goal is to get the coffee cooled down enough to begin drinking sooner without burning my mouth, so I add and mix immediately.
watching Rachel Ray..is it not better to add oneingredient to another in as hot a situation as possible..aids in blending?
i know if you add that dry coffee creamer to a luke warm cup of java..it clumps up..right?
Based on my experience, that's true.
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
