Hertz Contact Stress for static condition
The discussion revolves around calculating Hertz contact stress for side guide rollers on a vertical gate, specifically under jamming load conditions. The user has derived a formula for contact stress but is uncertain about the allowable stress for static conditions, as existing standards primarily address dynamic contacts. Suggestions include using allowable bearing yield stress or tensile yield strength, but concerns are raised about these being overly conservative compared to higher allowable stresses in existing standards. The user seeks clarification on the sources of these allowable stress factors from USACE and DIN standards. The conversation emphasizes the need for appropriate guidelines for static contact stress in infrequently loaded rollers.
servaa
Hi all,
I am designing a set of side guide rollers for a vertical gate. There are four rollers on the gate (two on each side), and the rollers are designed for jamming load condition (they are not loaded most of the time). When jamming happens, one top roller and one bottom roller (on the opposite side of the jammed top roller) will be in contact with the rail, resisting tilting moment caused by hoist load. I was able to calculate hertz contact stress on rollers from Roark's as follows:
stress = 0.798*sqrt(p/(Kd*Ce))
where p is applied load, Kd is equal to roller diameter, and Ce is some constant based on poisson's ratio and young's modulus of roller/rail material.
I am not sure though, what my allowable stress is in this case. I was able to find some criteria and standards that define allowable contact stress for wheels such as DIN 19704 (german), US Army Corps Engineering Manual EM 1110-2-2703, but the allowable stress defined in these standards seem to be for dynamic contacts.
The rollers that I'm designing is not going to be loaded repeatedly (maybe once in 5 years or so) and I think I need allowable static contact stress. Does anyone know how to approach this...??
Thanks a million!
servaa: Assuming you do not want the contact surface to yield, I think you could use the allowable bearing yield stress, which you could assume to be 1.5 times the allowable tensile yield stress. Or if you want to be more certain to not yield the contact surface, I think you could use the tensile (or compressive) yield strength.
nvn,
Thanks for info. Could you tell me what your source is..? Using allowable bearing stress seems to be a bit too conservative, as the allowable stresses defined in the standards that I mentioned are quite higher than those (2~2.5 times yield strength for USACE and 1.8 times ultimate strength for DIN standard).
Thanks!
I don't have a good reference for that.
may I know where I can find the 2.5 factor in USACE I mean section...
thanks
servaa said:
nvn,
Thanks!
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
