Hi. I'm testing a PMT and I'm surprised by the following. With power
  • Thread starter Thread starter Ravaner
    Hi Power Testing
The discussion centers on unexpected voltage readings from a photomultiplier tube (PMT) during testing, specifically measuring -126 V with a -900 V power supply and no charge between the output electrode and ground. Participants explain that PMTs convert photons into current through a multiplication process involving multiple dynodes, which can lead to significant voltage outputs depending on the gain of the connected current to voltage converter. The high voltage reading may be influenced by the experimental conditions, including ambient light levels in the room. There is uncertainty about typical PMT voltage outputs, with the consensus that -126 V is unusually high. Overall, the conversation highlights the complexities of PMT operation and the factors affecting voltage measurements.
Ravaner
Hi. I'm testing a PMT and I'm surprised by the following. With power supply (-900v on K) and with no charge between output electrode and ground, I measure -126 V same with scope (Zin = 1 M) or DVM (Zin = 10 M). I must precise that this experiment has be made in a room not completely dark. Can someone explain why such a high voltage ?
Well, a photomultiplier, from my understanding, converts photons into current. When a photon strikes the first plate it releases an electron if the photon energy is greater than the work function of the plate. This electron is accelerated by an electric field to the next plate knocking off another electron, so now you have two electrons. These two electrons are accelerated and hit the next plate creating two more electrons. These four electrons hit the next plate and create 4 more electrons, and so on. You get multiplication by using a large number of plates. This generates a fairly large current from a very small number of photons. The photomultiplier is generally used with a current to voltage converter. Depending on the gain of this current to voltage converter your voltage could be very small or very large. You can estimate the number of photons striking the first dynode based on the gain of the current to voltage converter, the output voltage, and the number of dynodes in the PMT.
I have never used a PMT though so I am not sure what voltages these things typically output. -126 volts seems very high. Maybe you're right...maybe the room isn't completely dark.
-Matt Leright
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
