Building High Voltage Supplies for Amateurs: Safety and Considerations
The discussion centers on building high voltage supplies for amateur projects, specifically a Cockcroft-Walton voltage multiplier for an electron accelerator and a fuser. Key questions include whether the multiplier can operate on constant DC or requires pulsed DC or AC, and the sourcing of high voltage diodes and capacitors. Suggestions include using a Van de Graaff generator or EHT supplies from analog TVs, both of which are safer alternatives. The conversation highlights the dangers associated with high voltage projects, emphasizing the need for proper safety measures and caution. Ultimately, the thread was closed due to concerns over the risks of amateur high voltage generation.
wrath90210
High voltage supply questions! :)
Ok, well a few friends of mine have come together to build a fuser and an electron accelerator.
I have obtained an NST at 20ma 6 kv DC , but would like to build a crockcroft walton voltage multiplier for the accelerator. My question is, will this setup run off a constant DC ? Or must it be a pulsed DC or an AC current. My voltage goal is +/- 100kv at no load. What parts and what method would be needed to construct this. (as in where to find the HV diodes, and what type of capacitor) I'm aware i could run the CW multiplier off of the house current, but the amperage is too much for the wire.
Also for the CW multiplier, could home made laden jars be used? And I've seen some built with a rectifier, why is this if it is supposed to convert ac to a higher dc voltage on its own.
The other power supply witch is more ideal for the fuser, needs an ability to take my 6kv NST DC, and up it to at least 25 kv 20ma DC at a constant rate. How would i do this? Capacitors in series are a daunting task. Would it be much easier to build a ready made power supply? Thanks to all!
Sam
You could consider getting a Van Der Graaf generator. These generate 300000 volts on a good day and at a few mA. Education supply companies carry these and they are not expensive.
Another easy source of high voltage is the EHT supply in analog TVs. This would be about 35000 volts. With the introduction of digital TV and the cessation of analog broadcasts in some countries, analog TVs should be available pretty easily.
This supply and others in a color TV set are dangerous, of course, and you may need to get advice on using them safely.
Do you have an evacuated chamber to accelerate these electrons in, or are you planning to do it in air?
If you don't know and can't guarantee to implement all the safety measures needed for operating with very high voltages then the VDG Generator is by far the safer option. It can only give you an annoying little jolt. A TV EHT supply could kill you.
The diodes for a high voltage Cocky Wally could be hard to find and expensive. Nearest thing could be the 'stick' diodes in TV CRTs.
Well the original idea was to create an accelerator that we could charge up capacitors using the CW or VDG, and then release this energy into the magnets. And yes these are being accelerated in a vacuum.
I'm not comfortable with this discussion of HV generation by amateurs (the OP) -- it falls under the "dangerous activities" portion of the PF rules. Sorry, thread closed.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
