I Impact on Earth: Calculating Energy
  • I
  • Thread starter Thread starter mukuruku
    Earth Impact
To classify the impact of an object hitting Earth based on its mass and velocity, understanding the object's shape and density is crucial, as these factors significantly influence the impact effects. An online tool is available for calculating potential impact outcomes. The discussion highlights that Earth’s atmosphere alters the dynamics of falling objects, with examples like a flat sheet of paper illustrating this concept. For dense spherical objects, specific equations may exist to predict impact results. Accurate classification requires considering both physical properties and atmospheric interactions.
mukuruku
Hey guys,
I have object i know its mass and velocity so i have energy. I need some king of classification of what impact it will make if it hits earth.
Astronomy news on Phys.org
Here’s an online tool. https://impact.ese.ic.ac.uk/ImpactEarth/ImpactEffects
As a side note, Jay Melosh did a Ph.D. at Caltech under Gell-Mann on quarks. He is known for his research on the mechanics of impact cratering. There are many paths for a physicist to take. He died a couple of years ago. May he rest in peace.
mukuruku said:
Hey guys,
Because Earth has an atmosphere, it makes a huge difference what size and shape it is. For example, a flat sheet of paper flutters as it falls, the mass and velocity of the paper make little difference.
If you mean a dense spherical object, there may be equations.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
