Is the Electric Field Inside a Hollow Dielectric Sphere Zero?
  • Thread starter Thread starter -EquinoX-
    Dielectric Sphere
The discussion centers on determining whether the electric field inside a hollow dielectric sphere is zero. The user has attempted to solve the problem by analyzing electric fields generated by charge elements on the sphere's surface and using Gaussian surfaces. They express that the net electric field at any point inside the sphere should equal zero if the contributions from all charge elements cancel out. The user seeks further guidance on how to proceed with the proof. The conversation highlights the need for clarification on applying Gauss's law in this context.
-EquinoX-
I am asked to find if there exists an electric field of a hollow dielectric field at a sphere is 0 and proof it.
I've drawn this picture:
http://img19.imageshack.us/img19/2295/hollowp.th.jpg
\omega \rightarrow 0
\delta q \rightarrow dq \rightarrow 0
E1 = k \frac{dq1}{r1^2}
E2 = k \frac{dq2}{r2^2}
if \vec{E_1} + \vec{E_2} = \vec{0} for p
\vec{E_net} = \vec{0}for all p
k \frac{dq_1}{r_1^2} = \frac{k\sigma\dA_1}{r_1^2}
k \frac{dq_2}{r_1^2} = \frac{k\sigma\dA_2}{r_2^2}
Explanation of the picture:
1. The two dotted circles are gaussian sphere each with radius r1 and r2.
2. The solid circle is the hollow dielectric sphere viewed from one side
3. P is just a point inside the dielectric sphere
So far this is all I got, can someone please guide me what to do next in this proof..
anyone?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
