Home work with set builder notation
4 replies · 6K views
kkp
Ok, I am needing help turning (2, 5, 10, 17) into set builder notation. I know to get these you add odd numbers 3, 5, 7 but I can't wrap my mind around putting this into notation.
In other words, you are looking for a formula. Check for a changing difference between consecutive terms.
It's pretty pointless to use set builder notation for such a small set. (Homework always seems that way, doesn't it?)
Keep in mind that set builder notation is of the form
{expression | for <variable(s)> in {a bigger set} such that <condition>}
Here, you're working with integers, so the "bigger set" is going to be Z or Z+ or something.
The tricky part is figuring out a useful condition. For example, if your set was {2, 3, 5, 7, 11}, you could have said: {x | x in Z+ where x is prime and x <= 11}.
This question is silly. Here are some equally silly answers.
[tex]\{n | n\in\{2, 5, 10, 17\}\}[/tex]
[tex]\{n | (n-2)(n-5)(n-10)(n-17)=0\}[/tex]
[tex]\{n^2+1 | 1\le n\le4\}[/tex]
The polynomial in the second answer can be rewritten as n^4 - 34n^3 + 369n^2 - 1460n + 1700, if you prefer.
How exactly to convert this into set builder notation, not sure; but I did some checking on the sequence of numbers.
The first term is obviously just 2.
After that, the next terms conform to 2 plus the sumation as index goes from 2 to i of three plus two times the expression (n-2);
In other words, I'm saying from the second term onward, the term is
2 + summation from 2 to i of (3 + 2(n-2)).
Some variation from that pattern might be possible (not sure) after n=4, since we might not be sure if only four terms as originally given were enough to build the pattern.
