Homework Help: Solving for Kinetic Energy and Speed of a Rebounding Tennis Ball
  • Thread starter Thread starter Turkish
    Homework Motion
A tennis ball with a mass of 0.20 kg is released from a height of 2.0 m and rebounds to 1.5 m. The kinetic energy just before impact is calculated to be 4 J, with a speed of approximately 6.3 m/s. After the bounce, the kinetic energy is determined to be 1.6 J, corresponding to a speed of about 5.48 m/s. The energy loss between the initial release and the maximum height after rebounding is found to be 2.4 J. Consistent unit usage is emphasized for accurate calculations.
Turkish
Hi again.
I have 3 sets of questions which I spose are fairly easy for the ones here.
1) A tennis ball of mass 0.20kg is released from rest at a height of 2.0m above a concrete floor.
It rebounds to a height of 1.5m
a) Calculate its kinetic energy and speed just before impact
b) calculate its kinetic energy and speed just after impact
c) calculate its loss of energy between release and its maximum height after rebounding
I have managed to solve a) I did, V^2 = U^2 + 2as
So, 0^2 + 2*10*2.0 = 6.3 So the Velocity is 6.3m/s
Therefore, Kinetic energy = 1/2 mv^2
So, 0.20 * (6.3*6.3 = 40) / 2 = 4J
But I don't understand how I can do b and c, can someone please help me :) Thanks in advance.
Think about all of this in terms of kinetic energy. PE is all it has before it is released, and
PE = mgh = .2*10*2 = 4.
Just before impact, PE = 0, and so all energy is kinetic, i.e. KE = 4
.5*m*v^2 = 4, m*v^2 = 8, v^2 = 40, v = 6.32
So far so good.
Now since it came back up to 1.5 m, PE = mgh = .2*10*1.5 = 3. Did the ball lose any energy between right after hitting the floor and going back up to 1.5? Nope. It was in the air. So KE = 3. Do you see this? It's important. Because PE is 3 after the bounce, KE right after the bounce must equal this, because, once again, PE = 0 at that point.
Thus,
3 = .5*m*v^2, 6 = m*v^2, 30 = v^2, v = 5.48 or something.
And so what is the loss of energy? Why, it's simply the change in potential energy. Which is 1.
For part b, you can use the same equation V^2 = U^2 + 2as, but this time the initial velocity (U) is the final velocity from part a (6.3 m/s). The final velocity (V) would be 0 m/s since the ball comes to a stop at the maximum height. The acceleration (a) would be -10 m/s^2 since the ball is decelerating due to gravity. Plugging these values into the equation, you should get a final kinetic energy of 1.6J.
For part c, you can find the difference between the kinetic energy just before impact (4J) and the kinetic energy just after impact (1.6J). This would give you the loss of energy between release and maximum height after rebounding, which is 2.4J.
I hope this helps! Remember to always pay attention to the units and make sure they are consistent throughout your calculations. Good luck!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
