How High is the Table in This Projectile Motion Problem?
  • Thread starter Thread starter westmarch
    Homework
To determine the height of the table in the projectile motion problem, the horizontal distance of 0.51 m and the horizontal velocity of 1.2 m/s can be used to calculate the time it takes for the marble to hit the cup. Using the time of flight, the height can then be found using the kinematic equations for vertical motion. A diagram can help visualize the problem and clarify known variables. The discussion emphasizes the importance of understanding kinematic equations for solving projectile motion problems. Assistance is sought to catch up on homework after an absence due to illness.
westmarch
Homework Help, Please...
Projectile Motion Problem solving, The problem is:
Melanie rolls a 10-g marble down a ramp and off the table with a horizontal velocity of 1.2m/s. The marble falls in a cup placed 0.51 m from the table's edge. How high is the table?
n/a since i was absent for about a week due to sickness, I need somebody that would please help me with these problems i got about 11 of them i'd repay you back somehow, I need to get caught up.
Do you have any ideas on where to start? I would start by drawing a diagram and labelling the things you know. Do you have your kinematic equations in front of you?
