Stuck on Elevator Weight - Analyzing the Readings
When an elevator moves upward at a constant velocity, the scale reads 600 N, indicating the person's weight. As the elevator slows down to a stop, the scale will register a value less than 600 N due to the reduction in acceleration. When the elevator is stopped, the scale will show exactly 600 N, reflecting the person's actual weight. During the descent, as the elevator accelerates downward, the scale will register a value less than 600 N again. The forces acting on the person include gravitational force and the normal force from the scale, which changes based on the elevator's acceleration.
hatingphysics
:confused: I am having trouble answering this question...what is the answer?! HELP
Suppose you are in an elevator that is moving upward with a constant velocity. A scale inside the elevator shows your weight to be 600 N. (a) Does the scale register a value that is greater than, less than, or equal to 600 N during the time when the elevator slows down as it comes to a stop? (b) What is the reading when the elevator is stopped? (c) How does the value registered on the scale compare to 600 N during the time when the elevator picks up speed again on its way back down? Give your reasoning in each case.
Draw a free body diagram. What forces are acting on the person?
