Hooke's Law: Mass vs. Length Data Analysis
  • Thread starter Thread starter audreylynn
    Hooke's law Law
To determine if a spring obeys Hooke's Law using the provided mass and spring length data, first identify the equilibrium position, which is 15.7 cm. The force exerted by the mass can be calculated using the equation F = k(y₀ - y) - mg, where y₀ is the equilibrium length, y is the measured length, and g is the gravitational constant. By substituting the mass and spring length values into this equation, one can solve for the spring constant k. To confirm compliance with Hooke's Law, plot the mass against the extension; a straight line indicates the law is obeyed, with the gradient representing the elastic constant k. This analysis effectively demonstrates the relationship between force and displacement in the context of Hooke's Law.
audreylynn
If I'm given a set of data such as...
Mass(kg) Spring Length(cm)
0.0 15.7
1.0 16.5
2.0 17.8
3.0 19.3
and so on...
How do I determine whether or not the spring is obeying Hooke's law?
I'm not sure what k is equal too.
And is 15.7 the equilibrium?
F = kx. If the force is zero, then the displacement should be zero, so you should take 15.7 cm as your equilibrium position. From there, it is simply seeing how well the force scales linearly with displacement. The force here being provided by the attached masses.
You are hanging the mass from the spring vertically? If so, the equation is
F=k(y_{0}-y)-mg
Where y_{0} is the point of equilibrium. g= 9.8 m/sec^2 (gravitational constant), m is the mass
, and y is the measured length of the spring.
If the force is zero, i.e., the mass is in equilibrium,
k(y_{0}-y)-mg=0
Plug in the possible values for m and and y and if the equations are consistent(with y_{0}, and k being the unknowns), then hook's law is obeyed.
From the data, draw a graph of mass of spring (horizontal axis) against extension (vertical).
If it is a straight line then Hooke's Law is obeyed. The gradient is equal to the elastic constant, k.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
