Hooke's Law - System of Springs
The discussion revolves around applying Hooke's Law to a system of springs, specifically analyzing the equivalent spring constants for different configurations. The user initially presents a problem involving three systems with varying spring constants and seeks assistance. Participants suggest replacing springs in parallel with an equivalent spring constant to simplify the analysis. The conversation emphasizes understanding the principles of springs in series and parallel to solve the problem effectively. Ultimately, the user confirms that they resolved the issue after receiving guidance.
noobish
http://img529.imageshack.us/img529/3814/hookes.jpg
Assuming spring constant for system A (left) is k
Then system B (middle) is k/2 and system C (right) is 2k
http://img15.imageshack.us/img15/7238/87792676.jpg
How about this system? Thanks for helping.
replace the two springs in parallel with the spring with the equivalent spring constant. Now you have two springs in series.
How about it? Do you have a question? Showing us pretty graphs doesn't tell anyone what you're stuck on. Also, those bold sentences are there for a reason: use them. State the question, give the relevant equations, and show your attempt at a solution, and then maybe I can give you a hint (or someone else can -- I'm a beginning physics student as well, so I make a lot of mistakes!).
Assuming you understand these statements, which describe the effect of adding springs in series or parallel, you can apply them directly to the new system. Hint: Start by replacing the bottom two springs by with an equivalent single spring.
Looks like rock.freak667 beat me too it! :smile:
Thanks. Solved it. =D
