Hooke's Law with Series Springs
The discussion revolves around the application of Hooke's Law to determine the equivalent spring constant (Keq) for two springs in series. The user initially proposed that Keq = (k1k2)/(k1+k2) and sought validation for this formula. Responses clarified the relationship between forces and displacements in the system, emphasizing the need to express the equations correctly. The final consensus confirms that the equivalent spring constant for springs in series is indeed Keq = (k1k2)/(k1+k2). This formula is essential for solving problems involving multiple springs connected in series.
maulucci
The problem is in the attachment
F=-kx
k1x1=k2x1
I got as my answer Keq= (k1k2)/(k1+k2)
i just wanted to see if i had the right idea or no.
Welcome to PF;
... then you need to tell us the idea and not just the final result you got ;)
-k1x1=-k2x2=F
F=-keq*x
solving for x1
x1=[(k2)/(k1+k2)] +x2
putting into F=-k2x2+k2x1
F=x2 (-k1k2-k2^2+k2^2)/(k1+k2)
simplified
F=-[(k1k2)/(k1+k2)]*x2
then the Keq = (k1k2)/(k1+k2) ?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
