Compute the density fZ(z) for Z
In summary, for the first problem, the summation should be from K=0 to w instead of infinity, and for the second problem, the limits of integration should be from max(0, z-2) to min(2, z).
sneaky666
66
Let X~Geometric(1/4), and let Y have probability function:
pY(y)=
1/6 if y=2
1/12 if y=5
3/4 if y=9
0 otherwise
Let W=X+Y. Suppose X and Y are independent. Compute pW(w) for all w in R.
For this i am not sure i think its
summation from K=0 to infinity (PY=w-K)(1/4)(3/4)^K
where
(PY=w-K) = 1/6 if w-K=2
(PY=w-K) = 1/12 if w-K=5
(PY=w-K) = 3/4 if w-K=9
(PY=w-K) = 0 otherwise
Is this right?
2.
Suppose X has density fX(x)=(x^3)/4 for 0<x<2, otherwise fX(x)=0, and Y has density fY(y)=(5y^4)/32 for 0<y<2, otherwise fY(y)=0. Assume X and Y are independent, and let Z=X+Y.
Compute the density fZ(z) for Z.
For this is it
the integral from z-2 to 2 (x^3)/4 * (5(z-x)^4)/32 dx
Is this right?
For the first problem, your approach is correct. However, you should also consider the possibility that w-K is negative, in which case pY(w-K) would be 0. So the summation should be from K=0 to w instead of infinity.
For the second problem, your approach is also correct, but you need to consider the limits of integration. Since X and Y can take values from 0 to 2, the limits of integration should be from max(0, z-2) to min(2, z). This is because if z is less than 2, then the range of values for X and Y that would result in z would be smaller. So the correct integral would be:
fZ(z) = integral from max(0, z-2) to min(2, z) (x^3)/4 * (5(z-x)^4)/32 dx
What is "change of variables help"?
"Change of variables help" is a mathematical concept that involves transforming a problem into a different coordinate system or set of variables. This can simplify the problem and make it easier to solve.
Why is change of variables helpful?
Change of variables can be helpful because it allows for a different perspective on a problem, making it easier to understand and solve. It can also help to reduce the complexity of a problem and make it more manageable.
What types of problems can be solved using change of variables?
Change of variables can be applied to various types of problems in fields such as mathematics, physics, engineering, and economics. Some examples include integration, optimization, differential equations, and transformations in geometric problems.
How do you choose the appropriate change of variables for a problem?
The choice of change of variables depends on the specific problem at hand. It is important to consider the properties and constraints of the problem, as well as the desired outcome. Consulting with experts or using mathematical techniques, such as substitution or transformation, can help in selecting the appropriate change of variables.
Are there any limitations to using change of variables?
While change of variables can be a powerful tool, it may not always be applicable or the most efficient approach for a problem. It is important to consider the potential limitations and drawbacks, such as the complexity of the transformation or the loss of information, when deciding to use change of variables.
