Horizontal motion and vertical motion are effectively independant
Horizontal and vertical motions are independent due to the principles of vector analysis and Newton's second law (F = ma). The x and y components of a vector operate at right angles, meaning changes in one do not affect the other. In projectile motion, the vertical component is influenced by gravity, while the horizontal component remains constant in the absence of air resistance. This independence is supported by both theoretical understanding and experimental validation. Thus, it is mathematically and physically provable that horizontal and vertical motions operate independently.
Cheman
Is there a way to mathematically or physically prove that horizontal motion and vertical motion are effectively independant? ie - is it possible to derive this fact from, say, vectors?
I know that is is true - the parabola shape of projectiles wouldn't make sense otherwise, but is there a convincing proof for it? It would just allow me to accept this fact if i had a proof, and then i would be happy to use the procedure! :wink:
Thanks in advance. :smile:
When you drop something from a building, does it move eratically all over the place, or does it fall down in a straight line? (assuming nil air resistance)
I think the fact they are independent is just postulate.
To get the proof, do some experimentation.
Everything is only theory until you get down to the lab to check it out.
But surely it can be prooved mathematically?
it can be prooven mathematically by the analysis of experiments. It seems simple to understand, the vector is bromen up into two compnenets one vertical and the other horizontal. To understand why this happens is like asking why is there inertia. Why do bodies with mass oppose acceleration. Nobody knows, but it's just common sence.
Yes. The motion is determined by Newton II, F = ma, which is a vector equation. Since the two vectors are equal, their individual components must be equal. The x and y components of a vector are completely independent of each other, since the x direction is 90 degrees to the y direction.
force is what causes change in velocity, assuming no air resitance... a projectile changes velocity in the vertical direction during its flight... due to gravity. The horizontal however is constant... that proves it right there more or less. The horizontal remains the same regardless of the motion in the vertical direction due to gravity... need more than that?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
